jimbo@stn23
Gentlebeings,
I've done as much research as I can and have come to some following conclusions I'd be interested in knowing if they're correct. I have a new L6 on it's way to me.
The L6 should run just fine on two 17500 AW cells (I think), would there be a preference to IMR or would protected AW's be fine? I have AW 16340 cells, would the voltage from 3 cells (11.1v roughly) be too hard on the KL6 lamp assembly? (it's stock)
Being that I have a M4, I can lego a M3T by using my M4 bezel (is it a KT4?) on the L6 body and the appropriate 9 volt lamp assembly. I'd be using 3 primaries or 2 - 17500's.
Any advice you gents can share would be much appreciated. Thanks.
