Wuben
Page 1 of 28 1234567811 ... LastLast
Results 1 to 30 of 833
Thread: P60 modules - warm, neutral, cool white/XPG- XML / SST-50 -90 P60 modules (part 8)
    Default P60 modules - warm, neutral, cool white/XPG- XML / SST-50 -90 P60 modules (part 8)
    PART 8 !!! P60 Style Custom Drop - in modules for SF and other Products. (part 7 can be found here)
    Here I am offering P60 Style drop ins, they are available with Leds from the following manufacturers with some of the leds that will be offered are below.
    SSC Seoul - P7 , P4
    Cree - MC-E , XP-E, XRE , UV, XML , XPG are here in warm , neutral or cool white
    Osram - Diamond Dragon , Golden Dragon Plus, GDP IR/ Ostar IR
    Luminus - SST -50, SST -90
    K2 TFFC
    Rebel
    These modules will fit most flashlights that accepts a standard P60/D26 Style module.
    THESE DO NOT FIT OLD STYLE G2 HOSTS
    IF a GREAT host is needed here are some great hosts by Five Mega to look at (HERE)
    Here is one of the emitter in the base and converter board
    View of the module from the top and typical beam shot
    You can still see a bit of a doughnut hole in this picture but most of the time we can focus all or most of it out.
    This is a picture of the new reflector made for the Cree XPE XPG This gives a very smooth and concentrated hotspot.
    New OPTICS Modules for XRE
    All of the modules end up being as close to standard length as possible The large die leds are much thicker and there is a small possibilty that there will be a crack at the head and body. I keep all as short as possible so if there is a crack there is probably nothing that can be done.
    All hosts are slightly different and one module may fit tight in a SF product and a bit loose in a FM Nite clone or an FM C but they will fit all. One may need to have the spring cut down to allow the head to close or a whole spring may be needed to keep the module from rattling.
    Most LED's are carried in Cool White, Neutral White, or Warm white. They will be listed if in stock.
    Battery configs listed are for any battery that falls into the range listed.
    Seoul P7 $65 - 3.6v - 6volts ONLY /
    1- 3 or 5 levels direct drive or 3 level regulated /Cool White
    __________________________________________________ _______________________
    CREE LEDS
    http://www.cree.com/products/xlamp.asp binning and tint informaiton
    Cree XM-L $40
    2.8-6 volts only THERE ARE NO 8.4 VOLT DRIVERS NONE, NADA
    T6 bin 1C / 1D Cool White
    T50 flux bin E3 5000k daylight white
    T50 flux Bin E4 4500K neutral white
    T30 flux bin E7 3000K Warm White
    Available levels with memory
    1 level
    2 level HI / Low
    3 level Low / Med / High
    3 level Hi / Low / Strobe (rotation of levels may change between driver batches)
    5 level Low / Med / High / SOS / Strobe
    These are spaced the same as the SST-50 drivers are.
    They can be pushed at 3.1 amps.
    If you want to use continuously on high please use 2.8 amps, you will also get much better runtime.
    Either Smooth OR Op reflectors
    Potting with tape is a $5 option description for potting below.
    Cree XRE - XPE
    -$30 - 3.6 - 6 volts 3 level regulated high / med / low
    3.6 -8.4V regulated 3 levels high / med/ low (memory ?)
    XPE R2 or R3 available coolwhite / neutral (Q3 5B) and warm tints plus new XPE Green , Red, Amber
    Smooth OR OP reflectors are available
    Optics are for XRE emitters only
    / Cool white , neutral white and warm whites.
    8degree/ 60 degree.
    $37 for module and 1 optic $40 with 2 optics
    __________________________________________________ _________________________
    Cree
    XP-G -$35
    2.8-3.6 (levels are 100% / 40% / 5
    % ) *mixture of throw and flood*
    5 level high / med / low / SOS / Strobe with memory / 1.4 amp
    3 level high / med / low 2.8-6 volts with memory / 1.4 amp
    1 level 2.8-6 volts
    1 Level 4-14 volts / 1.4 amp
    3 levels high / med/ low / 3.6-9 volts no memory / 1.4 amp
    3 or 5 level 1v-4.2 volts for low voltage for A / AA lights NO L2R HOSTS they are not compatible with my low voltage drivers
    Flux Bins and tints that are available for XPG
    Q23000K 7A3 (90 minimum CRI) NEW
    Q3 3000 7C1 (85 minimum CRI)
    Q4 2900k 8A4 tint
    Q5 3000k 7A3 , 7B4 tint
    R3 4000k 5C2
    R4 4000k 5B3 tint /5B2
    R4 5000k 3C tint
    R5 5500k
    - 2T tints (Cool White comparable to WH tint)
    S2 6300k - 1T tints (coolwhite comparable to WF tint)
    DUAL XPG (Linger Special)$45 Any of the above bins are possible / 3 level 2.5 amp 3.6-6 volts max *Floody*
    DBS MODULES AVAILABLE ON REQUEST / brass pill only no reflector/ same price as regular modules, potting is available on these also.
    Thermal Potting available upon request $5 upcharge.
    Copper tape now included in price to pot a module with thermal epoxy.
    Potting is an option of filling the electronics cavity with thermal epoxy for heat dissipation and for shock.
    __________________________________________________ __________________________________________
    Cree MCE $ 65 - 3.6 - 6 volts/
    1 - level or 5 levels direct drive
    1 - 3 or 5 level regulated
    Cool - M bin WD, WG
    Cool - Nbin no tint supplied but pure white
    Neutral - Kbin 5B tint
    Warm bins JE5, JE6, KA3
    OSRAM LEDS
    Osram Diamond Dragon $40 - 3.6 -6 volts / 1or 3 level
    Ultra White /WARM WHITE/True Green / Red
    Osram Golden Dragon Plus $40 -3.6 - 6 volts Regulated high / med / low /
    3.6 - 8.4v 3 level High / Low / Strobe
    Ultra White, , Warm White tints
    Platinum Dragon Hyper-Red this is a true red no orange red. $40
    LUMINUS SST SERIES LEDS
    Luminus SST-50 - $65 - 2.8 -6volts only *good throw with adequate spill*
    direct drive
    1 or 5 levels only
    100% / 45% / 10% / SOS and Strobe
    Regulated
    1 level
    2 level --High - low
    3 level -- high - med - low
    3 level -- high - low - strobe
    5 level -- high - med - low - strobe -SOS The driver is the Shiningbeam driver 2.8 amps
    Driver Levels are 100% / 40% / 5%
    Flux Bins are
    6500K Cool White
    (W65S-GJ102-WJ-G4 )
    5700k (w57S-GJ201-WJ-H4 )
    4500k (w45S-GJ400-WJ-P3 )
    DBS MODULES AVAILABLE ON REQUEST *pill only*
    Luminus SST -90 -$80 - 2.8 -6 volts only *Floody*
    1 or 5 Levels direct drive
    Can also be used with 2.8 amp drivers used with XML's
    3000k warm 83CRI ( W30M-GK700-WK-U3 )
    Green - Red
    - Blue SST -90's also available - $80
    UV LEDS
    Cree UV XL 7090 $45 (395nm)3.6 v-6volts /1 level
    Nichia UV $125
    (365nm)3.6-6 volts 1 level (. Out of Stock No Estimation )
    I ALSO CARRY A BLOOD TRACKING PACKAGE THAT IS AVAILABLE WITH SPRAY BOTTLE FOR HUNTERS , PLEASE PM FOR DETAILS.
    OSRAM IR LEDS
    Osram Golden Dragon IR $45 (850 940nm)-3.6v- 6 volts /1 level or 1 level 4-14 volts
    Osram Ostar 21 watt IR (850nm 940nm) 9-16 volts 1 level
    Generic quad 10watt great for night pictures
    I also have
    Rebels CW / Neut/ warm high CRI/ Royale Blue
    K2TFFC CW / Neut/ warm
    Seoul
    P4 - CW / Neut / warm 90 CRI
    please PM for info on these
    ANY MODULES LISTED AS 6 VOLTS MAX CAN NOT BE USED WITH LIFEPO4 BATTS. THERE HAS BEEN TOO MANY PROBLEMS WITH THESE BATTS AND PROPER CHARGING METHODS. WARRANTY WILL NOT COVER BOARDS BURNED UP BY USING THESE BATTS.
    I try to keep the above listed led's in stock, I also try to keep the newest and most popular bins and color temps from cool whites / neutrals / and warm white high CRI models.
    Now as to level in drivers , most of the time the levels are fixed and can't be changed. Now that said some drivers may have groups so that I may be able to accommodate some changes not shown such as special strobe packages for bike riders and such.
    As new drivers become available the offerings will change on this page so please check it first. I often will have to change depending on what drivers I have available to me at the time so please check this page and I will update as needed.
    Please specify what host and batts you are using when inquiring about a module or led.
    Just remember if you don't see it or don't understand something just write as I don't mind helping but check this page first. These are not try and buy!
    Now that said the search button for the forum has a wealth of knowledge, much more than I can ever remember and usually with in days of a new led release runtimes and lumens are often posted please check this also.
    When ordering please post your order in this thread plus put details of what typed led ordered including choice of reflector / levels and type driver DD or regulated / check to see if address is visible . Also please list CPF Nickname in paypal notes. Shipping is 3 working days
    Make sure your address in paypal is correct becuase that IS WHERE IT WILL BE SENT.
    If you want it mailed to an alternate address Please make sure I acknowledge that the paypal address is incorrect.
    Do not send me an alternate address with out making it known the paypal address is incorrect, please state I want my parcel sent to an alternate address if this is not done I will think it is a duplicate address and will send to what is listed on PP.
    MY Paypal info in biography or PM for.
    Credit card users please add 4%
    Shipping Conus is included / International shipping is $5 for 1st class Int up to two modules , Priority Mail with tracking is $15 up to 3 modules , express mail and more than 3 modules quoted.
    Beam shots are posted below and new products will be posted below. Please send your beam shots and I will try to list when possible or create a link to them.
    I will as I can try to keep wall shots updated as for outside beam shots those will probably be left for others as my camera doesn't take good shots out side at night or could be the operator is not good enough
    New offerings will be listed below as they become
    available.
    D36 for M STYLE and M to C lights are (HERE)
    IN NEED OF A HOST THEN HERE ARE SOME GREAT FORUM MEMBERS THAT CAN HELP
    Here on BST get Five Mega 1 2 X 26500 host (Here) These are some of my favorites
    On marketplace get Fivemega 18mm Bodies in 5 Sizes Here
    Jason will take care of you.
    For milling of maglites and general millwork Will Quiles is the master and can be found (HERE)
    Jan 2010
    Alaska/Florida/Bangkok
    Default Re: P60 modules - warm, neutral, cool white/XPG- XML / SST-50 -90 P60 modules (part
    Want a P60 style, XM-L, 2 level, OP reflector. Having a hard time with my new Mac, plus first time back to CPF in a long time. Format has changed on Board....Can you help me here?
    Vinh K40. Vinh Eye40. Vinh S6330. Vinh TX25C. Vinh RRT-01. Vihn XM-L2 P60 Thrower (40K Lux!!)
    Flashaholic* radellaf's Avatar
    Apr 2002
    Raleigh, NC
    Don't feel like rewriting my whole review post but here's a beamshot showing the CRI 85 XP-G LED. My only other point is that I like the L-Mini 1A driver much better than the normal one. Plenty bright, totally manageable heat in the L2P host, and it's a far superior interface to switch modes based on brief periods of "off" vs. needing several seconds of "on" to prevent a switch.
    Enlightened aspirina750's Avatar
    Mar 2011
    Castelldefels, Spain
    PP sent for a XM-L 3 mode 2B @ 2.8A and 15$ shipping.
    Cheers
    Flashaholic Cypher_Aod's Avatar
    Apr 2010
    London, United Kingdom
    Yay! Good to have CPF Back up and running again!
    Nailbender - Any progress with the Nichia-UV dropins?
    Quote Originally Posted by kengps View Post
    Hi
    While the formatting may have changed the information is all there including prices and tints. If you have a specific question please PM me. I have rechecked the thread and have hopefully made is easier to read.
    thanks
    Dave
    [QUOTE=radellaf;3589040]Don't feel like rewriting my whole review post but here's a beamshot showing the CRI 85 XP-G LED. My only other point is that I like the L-Mini 1A driver much better than the normal one. Plenty bright, totally manageable heat in the L2P host, and it's a far superior interface to switch modes based on brief periods of "off" vs. needing several seconds of "on" to prevent a switch.
    Hi
    Thanks for re-posting the picts. Just for informative purposes I now have 90+CRI XPG's to accompany the 85+ CRI offering
    thanks
    Dave
    Quote Originally Posted by Cypher_Aod View Post
    Hi
    At this time I am not stocking Nichia's, I am still trying to dig out from orders postponed for the Chinese New Year.
    thanks
    Dave
    Apr 2010
    Quote Originally Posted by nailbender View Post
    Hi
    thanks
    Dave
    Fair enough then Dave. I'll use the money to buy something else thanks for the reply.
    If/When you get them back in stock, please make a thread, hopefully i'll spot it.
    Jan 2010
    PP sent for XM-L P60 drop-in. T6, 1D tint. 2.8 Amp, 2 level H/L. OP reflector. Goes in SF C2 with an 18650 Li-ion. Ship to my Florida address (not Alaska)
    Flashaholic mitro's Avatar
    Apr 2009
    Montgomery, IL
    DUAL XPG (Linger Special) $45
    Potting $5
    Total $50
    Thank you!
    Quote Originally Posted by mitro View Post
    Potting $5
    Total $50
    Thank you!
    Hi
    How about a little help on how many levels you want!
    thanks
    Dave
    Apr 2009
    Montgomery, IL
    Sorry, I was so excited by the 90 CRI LEDs that I got in a hurry.
    3 level H/M/L
    Thanks
    Paypal sent for a xml p60 dropin with smooth reflector. 3 mode high/med/low regulated 2.5 amp driver. Potted. 1d tint. $45
    Unique Transaction ID # 5CX81765KD053135D
    Apr 2002
    Raleigh, NC
    The 90CRI look at all different than the 85?
    Flashaholic* think2x's Avatar
    Jul 2009
    Pulaski, Va.
    Hi Dave,
    I got my 85 CRI single mode Linger Special while the site was down. I can't give this one enough thumbs up! I have it in an L2P behind a diffused UCL lens and it's like an artifact free incandescent flooder, Great work.
    Email for faster response because I'm not on here much these days. jamielorrie(at)yahoo.com
    Quote Originally Posted by radellaf View Post
    HI
    There is not a terrible lot of difference to MY eyes, the tint is slightly different but remember that Cree uses minimum CRI stats which means the 85CRI may be closer to 90 or at least 85 while the 90 could be a bit higher or right at 90, I am simply saying I can't see much difference but I am sure some eyes may be more sensitive. I purchase as with all emitters to give the widest choice as I can when I can finally find a place to purchase.
    Dave
    Hi Dave.
    A while back in another thread, you stated that you were able to create your drop-ins using the deeper reflector designed to fit into a Farka F8v5. Is this still the case? If so, are you able to make a 3 level DD low/med/high sst-90 4500k using the deeper reflector? I have a little custom project in mind.
    Thanks!
    Hi Dave,
    As usual, you propose as much choice as you can, so i wonder if you know when you could have some neutral XML ?
    The XML's i've got from you have the most pretty beam of all the lights i have, but i really prefer neutral tint to use outside.
    Tell me if you have any hint, but i know you will propose them as soon as you can.
    Thanks
    Hello!
    Any news on the A001 heads yet??
    Apr 2009
    Montgomery, IL
    I received my dropin in 49 hours from the time I sent my money. Unbelievable!
    Thank you very much and I can't wait to try it out!
    (and I'll be back as soon as neutral XM-Ls are available)
    Flashaholic* BLUE LED's Avatar
    Apr 2008
    UK
    Cree XM-L cool white, 2.8A regulated, high/Low, smooth reflector, plus potting with tape $45.00
    I will be a single AW 18650 2900mAh cell in an Oveready SF 6P host. I hope this is suitable for this P60 module. $5.00 for shipping to UK. Paypal sent $50.00 with CPF name etc
    Apr 2009
    Montgomery, IL
    Quote Originally Posted by think2x View Post
    Hi Dave,
    You know what the Linger Special with 85/90CRI and diffusion is? Its the P91 killer. Absolutely awesome. I love it.
    Paypal sent for SST-90. Neutral tint please. 3 mode if possible (H-M-L), otherwise 5 mode is fine... This will first live in a Solarforce L2 w/ 1x18650 AW protected cell... But will hopefully end up in a custom body with more power... What are the optimum batteries to get the most out of this drop-in? I guess I would get a lot more power in a 5mega 2x26500 with this SST-90? Whatever you recommend...
    Unenlightened
    Mar 2011
    Vancouver, BC
    Nailbender,
    I'm also interested in the A001 head when/ if available
    Quote Originally Posted by badtziscool View Post
    Hi Dave.
    Thanks!
    HI
    I actually stated that while they are deeper most of the extra length is in the pill. The reflectors are a few millimeters deeper but are also narrower at the emitter which could cause part of the wall needed to be bored to accommodate the large size of the SST 90. I have not had the need to bore one out to this extent but it will be close. if the sides end up being bored out it will cause the emitter to sit back farther in the reflector. This may or may not affect the beam. Again I have not tried this but I did look at it closely when previous asked about and it will be very close becuase of the shape of the reflector.
    As shown above there are no 3 level direct drive. I will eventually replace them but they are infrequently asked for and I have to buy quite a few to get them altered to 3 level. I have 1 and 5 level available.
    Dave
    PS as I am sure you know these will probably not fit in a Surefire.
    Quote Originally Posted by taratata View Post
    Hi Dave,
    Thanks
    Hi
    As I have already stated not long ago OF COURSE I will carry them as for when I won't say, if I said one week or two weeks I would get about 1 day past that time line and then the PM'S would flood in asking again when when when
    Check back every week and look up top, I will have some probably as soon as most and before others. Warm whites will be later as most vendors are slow to pick up on alternate tints and color temps.
    Thanks
    Dave
    Quote Originally Posted by seahunt View Post
    Hello!
    Hi
    I only have natural at this time, also these are not solarforce A001 heads but look just like them and I actually like them slightly better as it is hard to find some A001 heads with out the aggressive bezels.
    I will not even attempt to order any until the end of this month as factories are still digging out trying to fill the orders they received before and during the Holiday over there. While the calendar says it is only 2 to 3 weeks the factories quit taking orders from vendors about 2 weeks before and then take about 2 weeks afterward to get started up and fill any existing orders. I am still waiting on a few orders to be filled from late January and I have learned it is better to wait until late January if you want the right stuff to show up.
    Dave
    Mar 2011
    USA
    Hi,
    Has anyone tested the OTF or ANSI lumens of the NB XML drop-in? Thanks
    Mar 2011
    Oregon
    Dave rates his XM-L's at 650 Lm. I have one and it is bright! It can vary depending on set-up, batteries, reflector, bin, tint, 2.8A or 3.1A, ect. Every P60 host/set-up is different and will have a little different output.
