Sold/Expired P60 modules - warm, neutral, cool white/XPG- XML / SST-50 -90 P60 modules (part 8)
Status
Not open for further replies.
nailbender
North Carolina
PART 8 !!! P60 Style Custom Drop - in modules for SF and other Products. (part 7 can be found here)
Here I am offering P60 Style drop ins, they are available with Leds from the following manufacturers with some of the leds that will be offered are below.
SSC Seoul - P7 , P4
Cree - MC-E , XP-E, XRE , UV, XML , XPG are here in warm , neutral or cool white
Osram - Diamond Dragon , Golden Dragon Plus, GDP IR/ Ostar IR
Luminus - SST -50, SST -90
K2 TFFC
Rebel
These modules will fit most flashlights that accepts a standard P60/D26 Style module.
THESE DO NOT FIT OLD STYLE G2 HOSTS
IF a GREAT host is needed here are some great hosts by Five Mega to look at (HERE)
Here is one of the emitter in the base and converter board
View of the module from the top and typical beam shot
You can still see a bit of a doughnut hole in this picture but most of the time we can focus all or most of it out.
This is a picture of the new reflector made for the Cree XPE XPG This gives a very smooth and concentrated hotspot.
New OPTICS Modules for XRE
All of the modules end up being as close to standard length as possible The large die leds are much thicker and there is a small possibilty that there will be a crack at the head and body. I keep all as short as possible so if there is a crack there is probably nothing that can be done.
All hosts are slightly different and one module may fit tight in a SF product and a bit loose in a FM Nite clone or an FM C but they will fit all. One may need to have the spring cut down to allow the head to close or a whole spring may be needed to keep the module from rattling.
Most LED's are carried in Cool White, Neutral White, or Warm white. They will be listed if in stock.
Battery configs listed are for any battery that falls into the range listed.
Seoul P7 $65 - 3.6v - 6volts ONLY /
1- 3 or 5 levels direct drive or 3 level regulated /Cool White
_________________________________________________________________________
CREE LEDS
http://www.cree.com/products/xlamp.asp binning and tint informaiton
Cree XM-L $40
2.8-6 volts only THERE ARE NO 8.4 VOLT DRIVERS NONE, NADA
T6 bin 1C / 1D Cool White
T50 flux bin E3 5000k daylight white
T50 flux Bin E4 4500K neutral white
T30 flux bin E7 3000K Warm White
Available levels with memory
1 level
2 level HI / Low
3 level Low / Med / High
3 level Hi / Low / Strobe (rotation of levels may change between driver batches)
5 level Low / Med / High / SOS / Strobe
These are spaced the same as the SST-50 drivers are.
They can be pushed at 3.1 amps.
If you want to use continuously on high please use 2.8 amps, you will also get much better runtime.
Either Smooth OR Op reflectors
Potting with tape is a $5 option description for potting below.
Cree XRE - XPE
-$30 - 3.6 - 6 volts 3 level regulated high / med / low
3.6 -8.4V regulated 3 levels high / med/ low (memory ?)
XPE R2 or R3 available coolwhite / neutral (Q3 5B) and warm tints plus new XPE Green , Red, Amber
Smooth OR OP reflectors are available
Optics are for XRE emitters only
/ Cool white , neutral white and warm whites.
8degree/ 60 degree.
$37 for module and 1 optic $40 with 2 optics
___________________________________________________________________________
Cree
XP-G -$35
2.8-3.6 (levels are 100% / 40% / 5
% ) *mixture of throw and flood*
5 level high / med / low / SOS / Strobe with memory / 1.4 amp
3 level high / med / low 2.8-6 volts with memory / 1.4 amp
1 level 2.8-6 volts
1 Level 4-14 volts / 1.4 amp
3 levels high / med/ low / 3.6-9 volts no memory / 1.4 amp
3 or 5 level 1v-4.2 volts for low voltage for A / AA lights NO L2R HOSTS they are not compatible with my low voltage drivers
Flux Bins and tints that are available for XPG
Q23000K 7A3 (90 minimum CRI) NEW
Q3 3000 7C1 (85 minimum CRI)
Q4 2900k 8A4 tint
Q5 3000k 7A3 , 7B4 tint
R3 4000k 5C2
R4 4000k 5B3 tint /5B2
R4 5000k 3C tint
R5 5500k
- 2T tints (Cool White comparable to WH tint)
S2 6300k - 1T tints (coolwhite comparable to WF tint)
DUAL XPG (Linger Special)$45 Any of the above bins are possible / 3 level 2.5 amp 3.6-6 volts max *Floody*
DBS MODULES AVAILABLE ON REQUEST / brass pill only no reflector/ same price as regular modules, potting is available on these also.
Thermal Potting available upon request $5 upcharge.
Copper tape now included in price to pot a module with thermal epoxy.
Potting is an option of filling the electronics cavity with thermal epoxy for heat dissipation and for shock.
____________________________________________________________________________________________
Cree MCE $ 65 - 3.6 - 6 volts/
1 - level or 5 levels direct drive
1 - 3 or 5 level regulated
Cool - M bin WD, WG
Cool - Nbin no tint supplied but pure white
Neutral - Kbin 5B tint
Warm bins JE5, JE6, KA3
OSRAM LEDS
Osram Diamond Dragon $40 - 3.6 -6 volts / 1or 3 level
Ultra White /WARM WHITE/True Green / Red
Osram Golden Dragon Plus $40 -3.6 - 6 volts Regulated high / med / low /
3.6 - 8.4v 3 level High / Low / Strobe
Ultra White, , Warm White tints
Platinum Dragon Hyper-Red this is a true red no orange red. $40
LUMINUS SST SERIES LEDS
Luminus SST-50 - $65 - 2.8 -6volts only *good throw with adequate spill*
direct drive
1 or 5 levels only
100% / 45% / 10% / SOS and Strobe
Regulated
1 level
2 level --High - low
3 level -- high - med - low
3 level -- high - low - strobe
5 level -- high - med - low - strobe -SOS The driver is the Shiningbeam driver 2.8 amps
Driver Levels are 100% / 40% / 5%
Flux Bins are
6500K Cool White
(W65S-GJ102-WJ-G4 )
5700k (w57S-GJ201-WJ-H4 )
4500k (w45S-GJ400-WJ-P3 )
DBS MODULES AVAILABLE ON REQUEST *pill only*
Luminus SST -90 -$80 - 2.8 -6 volts only *Floody*
1 or 5 Levels direct drive
Can also be used with 2.8 amp drivers used with XML's
3000k warm 83CRI ( W30M-GK700-WK-U3 )
Green - Red
- Blue SST -90's also available - $80
UV LEDS
Cree UV XL 7090 $45 (395nm)3.6 v-6volts /1 level
Nichia UV $125
(365nm)3.6-6 volts 1 level (. Out of Stock No Estimation )
I ALSO CARRY A BLOOD TRACKING PACKAGE THAT IS AVAILABLE WITH SPRAY BOTTLE FOR HUNTERS , PLEASE PM FOR DETAILS.
OSRAM IR LEDS
Osram Golden Dragon IR $45 (850 940nm)-3.6v- 6 volts /1 level or 1 level 4-14 volts
Osram Ostar 21 watt IR (850nm 940nm) 9-16 volts 1 level
Generic quad 10watt great for night pictures
I also have
Rebels CW / Neut/ warm high CRI/ Royale Blue
K2TFFC CW / Neut/ warm
Seoul
P4 - CW / Neut / warm 90 CRI
please PM for info on these
ANY MODULES LISTED AS 6 VOLTS MAX CAN NOT BE USED WITH LIFEPO4 BATTS. THERE HAS BEEN TOO MANY PROBLEMS WITH THESE BATTS AND PROPER CHARGING METHODS. WARRANTY WILL NOT COVER BOARDS BURNED UP BY USING THESE BATTS.
I try to keep the above listed led's in stock, I also try to keep the newest and most popular bins and color temps from cool whites / neutrals / and warm white high CRI models.
Now as to level in drivers , most of the time the levels are fixed and can't be changed. Now that said some drivers may have groups so that I may be able to accommodate some changes not shown such as special strobe packages for bike riders and such.
As new drivers become available the offerings will change on this page so please check it first. I often will have to change depending on what drivers I have available to me at the time so please check this page and I will update as needed.
Please specify what host and batts you are using when inquiring about a module or led.
Just remember if you don't see it or don't understand something just write as I don't mind helping but check this page first. These are not try and buy!
Now that said the search button for the forum has a wealth of knowledge, much more than I can ever remember and usually with in days of a new led release runtimes and lumens are often posted please check this also.
When ordering please post your order in this thread plus put details of what typed led ordered including choice of reflector / levels and type driver DD or regulated / check to see if address is visible . Also please list CPF Nickname in paypal notes. Shipping is 3 working days
Make sure your address in paypal is correct becuase that IS WHERE IT WILL BE SENT.
If you want it mailed to an alternate address Please make sure I acknowledge that the paypal address is incorrect.
Do not send me an alternate address with out making it known the paypal address is incorrect, please state I want my parcel sent to an alternate address if this is not done I will think it is a duplicate address and will send to what is listed on PP.
MY Paypal info in biography or PM for.
Credit card users please add 4%
Shipping Conus is included / International shipping is $5 for 1st class Int up to two modules , Priority Mail with tracking is $15 up to 3 modules , express mail and more than 3 modules quoted.
Beam shots are posted below and new products will be posted below. Please send your beam shots and I will try to list when possible or create a link to them.
I will as I can try to keep wall shots updated as for outside beam shots those will probably be left for others as my camera doesn't take good shots out side at night or could be the operator is not good enough:D
New offerings will be listed below as they become
available.
D36 for M STYLE and M to C lights are (HERE)
IN NEED OF A HOST THEN HERE ARE SOME GREAT FORUM MEMBERS THAT CAN HELP
Here on BST get Five Mega 1 2 X 26500 host (Here) These are some of my favorites
On marketplace get Fivemega 18mm Bodies in 5 Sizes Here
Jason will take care of you.
For milling of maglites and general millwork Will Quiles is the master and can be found (HERE)
kengps
Alaska/Florida/Bangkok
Want a P60 style, XM-L, 2 level, OP reflector. Having a hard time with my new Mac, plus first time back to CPF in a long time. Format has changed on Board....Can you help me here?
radellaf
Raleigh, NC
Don't feel like rewriting my whole review post but here's a beamshot showing the CRI 85 XP-G LED. My only other point is that I like the L-Mini 1A driver much better than the normal one. Plenty bright, totally manageable heat in the L2P host, and it's a far superior interface to switch modes based on brief periods of "off" vs. needing several seconds of "on" to prevent a switch.
nailbender
North Carolina
Hi
While the formatting may have changed the information is all there including prices and tints. If you have a specific question please PM me. I have rechecked the thread and have hopefully made is easier to read.
thanks
Dave
nailbender
North Carolina
Hi
Thanks for re-posting the picts. Just for informative purposes I now have 90+CRI XPG's to accompany the 85+ CRI offering
thanks
Dave
Cypher_Aod
London, United Kingdom
Hi
At this time I am not stocking Nichia's, I am still trying to dig out from orders postponed for the Chinese New Year.
thanks
Dave
Fair enough then Dave. I'll use the money to buy something else :) thanks for the reply.
If/When you get them back in stock, please make a thread, hopefully i'll spot it.
kengps
PP sent for XM-L P60 drop-in. T6, 1D tint. 2.8 Amp, 2 level H/L. OP reflector. Goes in SF C2 with an 18650 Li-ion. Ship to my Florida address (not Alaska)
daguy80
Paypal sent for a xml p60 dropin with smooth reflector. 3 mode high/med/low regulated 2.5 amp driver. Potted. 1d tint. $45
Unique Transaction ID # 5CX81765KD053135D
think2x
Pulaski, Va.
Hi Dave,
I got my 85 CRI single mode Linger Special while the site was down. I can't give this one enough thumbs up! I have it in an L2P behind a diffused UCL lens and it's like an artifact free incandescent flooder, Great work.
nailbender
North Carolina
The 90CRI look at all different than the 85?
HI
There is not a terrible lot of difference to MY eyes, the tint is slightly different but remember that Cree uses minimum CRI stats which means the 85CRI may be closer to 90 or at least 85 while the 90 could be a bit higher or right at 90, I am simply saying I can't see much difference but I am sure some eyes may be more sensitive. I purchase as with all emitters to give the widest choice as I can when I can finally find a place to purchase.
Dave
badtziscool
Hi Dave.
A while back in another thread, you stated that you were able to create your drop-ins using the deeper reflector designed to fit into a Farka F8v5. Is this still the case? If so, are you able to make a 3 level DD low/med/high sst-90 4500k using the deeper reflector? I have a little custom project in mind. :)
Thanks!
taratata
Hi Dave,
As usual, you propose as much choice as you can, so i wonder if you know when you could have some neutral XML ?
The XML's i've got from you have the most pretty beam of all the lights i have, but i really prefer neutral tint to use outside.
Tell me if you have any hint, but i know you will propose them as soon as you can.
Thanks
Status
