Edit: Forget this mod... I have an XML 'Stubby' mod shown at the bottom of the first post in this thread:
FS: 1000 Lumen XML Maglite Mod With Voltage Monitor - Parts, or Complete Light!
Maglite D 'Stubby'
Here's a cool little mod that I did for setting up a large capacity single Li-Ion Maglite...
* Using a high capacity 32600 (or 32650, or 26650)
* And a Terralux Cree LED (TLE 6EXB) emitter
Basically a really nice capacity, very nice Maglite finish, and heavy duty side button forward clicky in a shortened configuration!
Nice to have a 6000mAh capacity battery that won't leak like an Alkaline...
Just check the battery voltage once in a while to make sure it doesn't get over discharged if your battery is unprotected... (Until you get the feel for how long it will go between charges)
Emitter:
TLE-6EXB items - Get great deals on Sporting Goods, Electronics items on eBay.com!
The TLE 6EXB emitter, is made to just replace the stock bulb. It's an easy change out!
It is the 140 lumen LED that is set up for 3 to 4.5 volts. (the driver is inside the emitter housing) This is perfect for the large capacity 32600 single Li-Ion.
So it's not a super bright light. But it will have a really great run time. (like about 10 hours) And still be fairly bright. Plus the nice sizing of the light, and a rechargeable Li-Ion that won't leak like an Alkaline...
Here's some battery sources:
I have 6000mAh 32650's here:
http://laserpointerforums.com/f64/fs-feilong-6000mah-32650-li-ion-batteries-71201.html
Here's a source for 26650's:
LiMnNi Rechargeable 26650 Cell: 3.7V 4000 mAh, 10A rated 14.8Wh - UN Approved (NDGR)
If you go with a 26650, I have the perfect size fiberglass tubing to make a sleeve that is available with the kit. (see pricing below)
Charger:
If you don't want to mess with magnets and spacers while charging, you will need this charger:
Ultrafire WF-188 Charger for 14500 / 17500 / 18500 / 18650 / RCR123 3.7 volt Lithium Battery Charger
Maglite 2 D available colors...
Pricing for basic 'Stubby' kit:
* Maglite 2 D host - $29 (or send me your Maglite - any D size Maglite can be cut down)
* Fiberglass sleeve for 26650 if needed - $7
* Re-size the host as shown above - $28
* Shipping will be based on PayPal fees plus postage. (PM for total)
Hope you like it!
P.S. I have some Maglite monster laser kits as well! Shown here:
http://laserpointerforums.com/f64/fs...cky-57278.html
Maglite D 'Stubby'
Emitter:
Charger:
Hope you like it!
