Klarus
Page 1 of 4 1234 LastLast
Results 1 to 30 of 96
Thread: Dorcy 1AAA review...
    Apr 2003
    COLORADO
    Default Dorcy 1AAA review...
    Just picked up the Dorcy 1AAA at Walmart today for $5.95. Was hoping to get the 1AA 3-LED, but oh well. First off, the construction is similar to a M@g product. The size is VERY big and bulky for a 1AAA light, and almost 1/2" taller than an ARC aaa. The head is almost 1" in diameter, and the reflector doesn't take up all the space in the head...not sure why [img]/ubbthreads/images/graemlins/confused.gif[/img]. They could have used a larger reflector to possibly increase output or throw.
    The tailcap has an "intermittent" button made of hard plastic...ugh. To use the light for constant on, twist clockwise and reverse to turn off and use intermittent. The metal hanger tab seems like an afterthought, and is attached to the tailcap button...hmmm.
    Overall, the light looks nice, but the hard tailcap button and huge size is a negative. The beam is full of "lumpy" rings, and no smooth transition to spill light.
    Beam(sry, poor pic!):
    http://img.villagephotos.com/p/2003-...cy1aaa0002.JPG
    Granted, its only $6, but the ARC aaa is superior in every respect. The beam pattern is pretty bad! Good for giving to your kid or a toolbox light. Just a FYI...
    Thanks!
    Default Re: Dorcy 1AAA review...
    lol aint bad for 6 bucks.id like to see that 3 led light to .hopefully they will get em
    Do the electronics fill the head or anything like that? Maybe the guts could be transplanted into a different light. They might make a nice mod for a Solitaire or one of those cheap 1aa keychain lights or something.
    *Retired* The_LED_Museum's Avatar
    Aug 2000
    Federal Way WA. USA
    I took a couple of pictures, but after checking my servers I've run out of room to put them anywhere. [img]/ubbthreads/images/graemlins/jpshakehead.gif[/img]
    The electronics package (a PCB with components mounted to both sides of the board) go inside the head, but the PCB with a (+) battery spring sticks up (not counting the spring) about 1/4 of an inch from the bottom of the head as it's removed from the flashlight body.
    A picture would show this better than words, but I don't have anywhere to put it until I {vulgar term for feces}can a website or two to make room. I can email the pictures directly to you if you want.
    *Flashaholic* IsaacHayes's Avatar
    Jan 2003
    Missouri
    I thought when Craig reviewed them they had rubber tail cap things? Is that only on the larger ones? which ones?
    Apr 2003
    COLORADO
    As for the rubber tailcap, it was a hard plastic. The 8 LED model has rubber tailcap from what I've seen, but this one does not unfortunately...
    Aug 2000
    Federal Way WA. USA
    All four Dorcy LED flashlights have rubber or black plastic tailcap thingies. I just examined them more closely, and the 2-C 8-LED model has a rubber thing on its tailcap, and the other three have a hard black plastic "button" on their tailcaps.
    Aug 2002
    WI
    I just bought one tonight. Push button functions like the Stream Light Stylus, push for momentary on or screw it down tight for constant on. It would be nice if it was a clicky, but than I have seen enough clickies die. It should make a nice bargain carry light to replace my broken cliphanger light.
    I also saw two new LED Garrity lights on the Walmart flashlight rack. Both are 3 AAA cell lights. One was a head lamp and the other was a torch both had a 12 something price on them (a bit steep?).
    I was tempted by the torch but held off. Maybe someday I will catch it on the clearance rack.
    Feb 2002
    n.e. philly
    i love my new dorcy 1aaa light. picked up a grey and red model tonight.
    also got the garrity 3aaa light. 5 modes but cheap looking plastic case and weird battery holder. 2 batts go negative against the spring while one goes positive to spring.
    different for sure!
    i wouldn't count on it for much except inside use.
    waiting for the 1aa 3 led model to arrive at walmart!
    Aug 2002
    WI
    I got a chance to play with my Dorcy 1AAA last night. I had it on solid for about 20 min. Nice little light for $6. The only other lights you are going to find in this price range are the cheap China import key fob lights. At the price this thing sells for, I'm tempted to buy one in each color.
    Size wise:
    3/4" at the head
    5/8" at the tailcap
    9/16" along the battery tube
    total length:
    3-3/8"
    The wall thickness is heavy enough that it should not ever get bent.
    Default Re: Dorcy 1AAA review... *DELETED*
    Post deleted by raggie33
    Flashaholic* Phaserburn's Avatar
    Mar 2003
    Connecticut, USA
    I saw the new WM lights too. A beamshot of the AAA Dorcy, Garrity and Arc would be great. Anyone?
    Flashaholic Starshiptrupr's Avatar
    Jul 2003
    Tennessee
    I was going see if walmart had the new garrity led lights when I found this, I had kinda' stopped looking for the new dorcy lights. I have to agree it's cheap but pretty cool for six bucks. The lens is so-so but doesn't seem to have an impact on the beam. Also, the beam on mine seems to have a more smooth transition between rings than the photo in the first post. It's not beautiful by any means though.. I did have to file the tailcap spring a bit, it was sharp and actually digging into the battery.
    I don't have an arc aaa yet *ducks and dodges*, but it's a lot better than the solicrap I bought years ago and was never practical/useful enough to carry.
    *Flashaholic* Flying Turtle's Avatar
    Jan 2003
    Apex, NC
    They must have had me in mind- cheap and small- the light that is. Anyway, for the price this is really a pretty nice light. Compared side by side it's a wee bit brighter and whiter than my standard ARC. It certainly won't take ARC's place in the pocket. The wide head and additional length makes it more like an Infinity in size. That wider head does give it maybe half again wider flood than ARC. The finish will probably wear off pretty easily and the rubber collars, which look good and give some grip, will eventually crack and fall off, but that is a bit nitpicky. I imagine the lens can scratch easily, too. These faults, though, for six bucks I can overlook. In fact, it was nice enough for me to run back to WallyWorld to grab another for my son. Now if I can only figure out some place where I don't already have a light. [img]/ubbthreads/images/graemlins/yellowlaugh.gif[/img]
    Flashaholic* pedalinbob's Avatar
    Dec 2002
    Michigan
    i havent seen one yet, but i think it might be a very nice light for a non-flashaholic.
    inexpensive, small-ish, and decent brightness and runtime.
    however, my wife has officially confiscated my spare arc aaa (after the blackout), and it happily resides on her keychain. she really likes it, and i am sure she would not give it up for the little dorcy.
    Bob
    Default Re: Dorcy 1AAA review... *DELETED* *DELETED* *DELETED*
    just got one.as stated above its not a bad light at all for the price .its pretty bright.and im going back to get a few more.
    has anyone seen the garity 5 function led light they had.i didnt get a good look i was in a big hurry ..and walmart was so crowded.it seems to have 5 levels of brightnes.anyone know where a review is?
    btw anyone know.what led this uses.and im sure it aint regulated is it
    Aug 2000
    Federal Way WA. USA
    Judging from the internal style of the leadframe assembly, it looks like they're using a Nichia NSPW500.
    I don't know what color or brightness rank the LED is... probably color rank B and brightness rank R or S.
    There appears to be a transistor and a diode(?) on one side of the board, and a ferrite core inductor, a resistor, and two caps on the other side. I don't know how the circuit works, so I don't know if it's regulated or not.
    i cant even get mine apart looks as if the head unscrews but it dont ,well at least it dont with the force i feel safe useing
    I picked up 2 of these lights today. Seem pretty good for about $6. I was going to get a cmg ultra for night stand use. Not any more....
    Mar 2002
    NW FL
    Those of you that picked these lights up at WalMart, did you find them in the flashlight section, or did they have them somewhere else in the store? WalMarts in my area don't seem to have them yet...or they do and I just can't find them [img]/ubbthreads/images/graemlins/confused.gif[/img]...
    PJD
    camping and hunting pjd
    Mar 2002
    NW FL
    Thanx, raggie! I'll be paying them a visit again tomorrow!
    PJD
    Flashaholic* Wits' End's Avatar
    Nov 2001
    Remote NEast Minnesota, next to Lake Superior
    I saw the other lights at WM also, has anyone else seen the rechargeable LED light? I think it was Energizer.
    Mar 2002
    NW FL
    I picked up 2 of the Dorcy 1AAA lights, and I have to say that for 6 bucks I think they're a good deal. They may not be as "refined" as the ArcAAA or Ultra G, but they're every bit as bright as either one of those. They won't replace my ArcAAA or Ultra G by any means...but like I said, for 6 bucks they're nice lights!
    PJD
    *Flashaholic* PlayboyJoeShmoe's Avatar
    Sep 2002
    Shepherd, TX (where dat?)
    I saw (and got) one of the rechargable LED lights.
    I would imagine in total dark, it would be bright enough. I find it somewhat unremarkable with any other light.
    Also the LED in mine is crooked. It goes off at a slight angle from straight. As a result, the spot beam from the focusing place on the lense has a soft edge on one side. I see no way short of destruction to get in there and straighten up the LED.
    It is neat in that it has a low power/nightlight mode so it will be easy to find in a power outage! Says it can go 80 hours in that mode too!!!
    I would say go ahead and grab one if you need a plug in light. Just look at it with a critical eye for LED placement!
    Flashaholic danielo_d's Avatar
    Jul 2003
    NorCal
    Hey, thanks guys. I didn't know that Wal-Mart started to carry these small dorcy LED lights til I stumbled across this thread today. Been looking around for them since I found them on their website at http://www.dorcy.com/41-4234.htm.
    Luckily, I took lunch and of course found myself in Wally World. Got me one and currently checking it out. Pretty cool for $6!!!
    While I was there, I saw a Garrity LED flashlight. It took 3AAA's and had 5 functions. Those functions were 3 levels of brightness and two signal/flash modes. I believe it had 3 LEDs, but not totally sure. It was about $15! Yellow plastic with black rubber trim and it was kind of angular, not tubular/cylindrical. That's about all I recall.
    Now off to play with my lil $6 fix for my habit. =-)
    Aug 2001
    VA
    here:
    Sep 2002
    New Jersey
    I bought the Dorcy 1aaa and Garrity 3aaa at Walmart two nights ago. The Dorcy is great! Good quality, smooth beam with brightness about the same as ARC AAA or Infinity Ultra. Nowhere near the quality of those lights, but for $6 it's an absolute steal. FANTASTIC! [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
    As for the Garrity, it doesn't appear to be regulated, has poor fit and finish, feels cheap, and has difficult access to the battery compartment, among other things. The beam is horrible! In other words, a typical Garrity light. [img]/ubbthreads/images/graemlins/frown.gif[/img]
