Question for all you Jetbeamers, I just picked up a new Jet 1 pro v3 with the warm Q3 led and I'm having problems trying to program this thing. I'm doing everything they say to do, but it will not go into program mode. Once in a while it will do it, but usually I have to quickly turn the tailcap 3 times to make it work. I've tries different batteries, but it doesn't help.
The light is supposed to be factory programmed for High, Low, strobe, but I found that the low is more like medium and can actually go a lot lower. I also wonder about the high level because the output doesn't beat my Zebralight SC50w+ in brightness. From the comments and specs I read it seemed like it should be brighter.
So, is there possibly a problem with mine where the circuit isn't working properly which could affect the UI and maybe the brightness too?
-Bill
-Bill
