Unclemonkey
I had a malkoff m61 in md2 host with factory installed battery station cr123's. It's output had finally drop off and would no longer go into high. I pulled batts and tested w/multi meter. Both batts read 2.92v?
I now have panasonic cr123's. As I noticed its output diminished, pulled batteries to check. They read 2.87/2.88v. It appears the panasonics ran at full power slightly longer. But still doesn't make sense, as stated it should run direct drive at 3.4v?
Anyone have any feedback? Am I testing correctly? Your help would be greatly appreciated.
