kerberos0023
:welcome: I sell this!
The 4th run will be limited to 4200mA 3-mode Direct Drive XP-G R4NW R5CW
The sale number is 10 in all.
The module sends it out from the end of January, 2011.
I begin to sell it for $180(4200mA 3-mode) $160(Direct Drive) including the EMS postage!
The GITD processing is plus $10.
This becomes very hot.
The use battery is with 3.7V Li-Io battery protection circuit.
If a light becomes hot, please cut the light which is in a dangerous state.
Please be careful to the handling.
After understanding, please refer as things mentioned above.
?This light creates excessive heat
?The consecutive lighting is dangerous.
?If a light is overheated, please turn off the light.
?This light may cause eye damage
?This light will burn the skin at close range.
?This light may cause combustibles to ignite
?This drop-in is a direct drive unit.
?IMR cells are not recommended.
When you used the large-capacity battery except 17670 and 18650 of the battery with the protection circuit, the possibility that an excessive electric current flows, and LED is broken is very high.
Because I sell 4200mA converter in After 2nd Run.
if you use a large-capacity battery except 17670 and 18650, please wait till then.
Please use only 17670 or 18650.
It is very likely that LED is broken!
:thumbsup:
I sell this custom Quad XP-G P60 module.
I begin to sell it for $160(DD) $180(4200mA 3-mode) including the EMS postage!
This light creates excessive heat.
Please use 18650 or 17670 expensive battery of the electric discharge performance.
The payment is PeyPal.
Post your order here and I will PM you the total along with my PayPal address.
Cutter-XPG25RDR5-CW (remodeling board 20mm)
Carclo 24mm Quad Optics
Quad XP-G Module 4200mA 3-mode
*3 modes: Low-Med-High
* Voltage input: 3V - 5.5V
* The memory feature will memorize the last mode
Quad XP-G DD Module
surefire 6P C2 normal body FIVEMEGA 26500
