Z
z_Bwana
Guest
I wanted to put a new M2 bezel on a new 6P host .... but have read there is a problem dissipating heat. Will be installing a Malkoff or NB module.
(1) Is the M2 bezel larger (does drop in size change ?)
(2) Is anyone using this configuration without problems.
(3)Is wrapping copper tape a viable solution to help transfer the heat to the host ?
(4)Is there no advantage for me to use the M2 bezel anyway ?
Thanks in advance
Thanks in advance
