Sold/Expired FS: P7 Mag Mod / Custom Heatsink Installed
jayrob
Northern CA U.S.A.
SOLD FS: P7 Mag Mod / Custom Heatsink Installed
SOLD
This is a great flashlight modification that is up for grabs...
The light is in perfect condition. Not a smudge...
I will go by 'order of post' for prospective buyers.
Here's the thread that shows all details of this build:
http://www.candlepowerforums.com/vb/...d.php?t=305460
* 2D Mag host (black)
* Custom heatsink installed
* Glass lens (clear) Or add $5 bucks for UCL glass lens
* Set up for using 2 X 32600 Li-Ion supply (batteries available if wanted)
* Can also use 2 X 26650's with the addition of a sleeve and tail cap spring mod. ($15 extra for my fiberglass sleeve and tail cap mod shown below)
Current Draw: Single mode (measured at the tail)
* 1360mA's - Estimated run time between charges: 3 1/2 hours... (2 X 5000mAh 32600's)
* The emitter is probably drawing around 2.7 Amps
Beam shot:
The face of the cave on my pool where the steps are, is 60' away, and the very back corner at the fence is 85'... :)
Asking $95 dollars plus shipping. (batteries not included)
If you would like a pair of 32600's with it, I will sell a set for $35 dollars for the pair.
PM for total...
Thanks! :)
Sleeve and tail cap mod for 26650's:
If you want to use 26650's instead of the 32mm batteries, then I have some perfect sized fiber glass material:
jayrob
Northern CA U.S.A.
Sorry, the crash from a couple of months back, somehow changed the notification on this thread. And I never got notified that you had replied to this thread...
The light has been sold...
