How to remove spacer in Inova X5T red LEDs?
AZLight
I would like to use two CR123s in the light for more distance. How do I remove the spacer inside the battery compartment? I tried to pull it out with a plier, but it did not cooperate. TIA.
AZLight
Is the red LED different than the other color LED? I do not believe Inova modify the electronics just for the red LED version.
jtice
West Virginia
I think the red LEDs take lower Volts. So thats why theres only one batt in the read LED versions.
Im not really sure though. /ubbthreads/images/graemlins/icon3.gif
Kiessling
Old World
yellow, orange and red LEDs take a lower voltage than the other ones, that is why there is only one 123 in the red X5T and a spacer (this solution stinks, I agree). I doubt there are "electronics" in the X5T, maybe a few resistors. If you put in 2 123s you'll most liekly kill the LEDs.
bernhard
