Z
z_jompsukka
Guest
hello. i guess it's just my luck that my first light starts acting up just after i hype it up in here.
the problem is that when setting a brightness mode, the light only ramps up for a few seconds, and the modes from 40%(about) to 100% (as indicated by the blinks) are the same brightness.
now the problem is this: i'm not sure if it just ramps up to max brightness too quick, or if i'm missing some brightness. i have nothing else to compare it to.
this happened after some metal shavings got caught up in the threads and it acted a bit weird for a while.
otherwise everything works fine, so do you more experienced people have any ideas as to what to look at?
