kerberos0023
Sell:custom Quad XP-G 5.6A 3-mode P60 module 5th Run *close*
Sell:custom Quad XP-G P60 module 5th Run
:welcome: I sell this!A new product!
5.6A 3-mode 3.7V Li-Io battery!
This module is most suitable for a large-capacity battery!
A small battery of the capacity.
When it is the low battery of the electric discharge rate, the module cannot output it.
The 5th run will be limited to 4.2mA 3-mode 5.6A 3-mode Direct Drive XP-G R4NW R5CW
The sale number is 10 in all.
I begin to sell it for $190(5.6A 3-mode) 180(4.2mA 3-mode) $160(Direct Drive) including the EMS postage!
The GITD?Ultra green/Ultra blue/Pure blue)processing is plus $10.
This becomes very hot.
The use battery is with 3.7V Li-Io battery protection circuit.
If a light becomes hot, please cut the light which is in a dangerous state.
Please be careful to the handling.
After understanding, please refer as things mentioned above.
?This light creates excessive heat
?The consecutive lighting is dangerous.
?If a light is overheated, please turn off the light.
?This light may cause eye damage
?This light will burn the skin at close range.
?This light may cause combustibles to ignite
:thumbsup:
I sell this custom Quad XP-G P60 module.
I begin to sell it for $160(DD) $180(4.2A 3-mode) $190(5.2A 3-mode)including the EMS postage!
This light creates excessive heat.
Please use 26650 or 26500 or 18650 or 17670 expensive battery of the electric discharge performance.
The payment is PeyPal.
Post your order here and I will PM you the total along with my PayPal address.
Cutter-XPG25RDR5-CW (remodeling board)
Original board
Carclo 24mm Quad Optics
Quad XP-G Module 5600mA 3-mode
*3 modes: Low-Med-High
* Voltage input: 3V - 5.5V
* The memory feature will memorize the last mode
Quad XP-G Module 4200mA 3-mode
Quad XP-G DD Module
surefire 6P C2 normal body FIVEMEGA 26500
