Scattergun
- Joined
- May 9, 2006
- Messages
- 485
I am looking for a driver to use in a P60-module I´m building. The LED will be run in a G2Z with a G2 bezel, wich means the heatsinking is lacking since the bezel and body are made of nitrolon.
What I need is a driver with an output of around 350mA and will run on 2xCR123. The diameter of the driver should be 17mm since I plan on using one of the generic DX-modules.
Any thoughts on wich driver to use?
