Was wondering if anyone has had any trouble removing the Mag C switch. I have used the same technique I used for my D lights. Removed the boot put the hex key in. But it does not seem to grasp the screw. Anyone else encounter this problem?
your switch has new screw it is not hex, but t8 star, also it has to be really thin shaft or it wont fit. thre was a thread here about new switch, can't find it
Thanks for all the links. Has someone found a specific brand size tool that works without any filling down? From what I gather a t7 or t8 torx screwdriver will do.
If you buy a new Maglite C switch it will come with 2 wrenches: hex and thin T8. I bought a Torx 8 and used a grinder to make the shaft of the driver the same size as the T8 tip. It works like a charm. I also bought some hex screws to replace the Torx 8 screw once it's out. That way all my Maglites use the same hex.
