RepProdigious
So i keep reading how people have difficulty opening light with glued parts only to get replies from other people to use pliers and a bench-vise. I dislike this method very very much because even if you use cloth/rubber to protect the light sooner or later you will damage your light by either scratching it or squeezing it! So here's my method that does not require any tools!
Here i go, i hope you guys can follow:
You will need:
-A light you want to open
-About 4 feet of paracord or other STRONG cord
-Couple rubber bands
-Two nice wooden sticks (i use pieces of old broom handles)
Optional for real locktite (not needed for the cheap chinese glue):
-Watertight bag
-Water
-Pan
Step one:
Cut the paracord in two pieces each 2 feet in lenght and tie them in loops:
Step two:
Optional: Put the light in the watertight bag and boil it for several minutes to soften the lockbonding agent
Wrap rubber bands around the two parts you want to unscrew from eachother. This will add grip and protect the finish on your light:
Step three:
Put the paracord under your light. Remember the basic rule; Righty tighty, lefty loosy! You want the looped end (not the knot) pointed in the direction you want to turn the part. This might be a bit difficult to visualise so here's some pics:
In my example when viewed from the reflector side the loop on the head is pointed counterclockwise ('lefty') and the loop on the neck is pointed clockwise.
Now get the knotted end of your rope through the loop;
And tightly wrap the knotted end around the light in the direction of the loop which also should be the direction you want to turn the parts:
The idea behind this is that as you pull the knotted end of the loop the rope will tighten in on itself, grabbing and squeezing the light stronger the more force you apply. The rubber bands will turn this grabbing force into grip!
Step four
Take your sticks and put them through the loops just behind the knots like so:
And now comes the part where you will need to put all your best dexterity to use, you will need to keep the light perpendicular to your sticks while slowly pushing the sticks in the 'unscrew' direction:
And like this you should be able to open up any light, also works flawlessly on quark heads without applying any heat!!!
And because you only use rubber, nylon and wood damaging the light would be pretty much impossible!
Hope you guys like!
You will need:
-Watertight bag
-Water
-Pan
Step one:
Step two:
Step three:
Step four
Hope you guys like!
