KiwiMark
I have used a Turnigy Accucell 6 and a Turnigy Accucell 8 for a while now to charge my Li-ion cells and some NiCd & NiMH cells too. They are both good chargers that have lots of good features and are very versatile.
But now my iCharger 106B+ has arrived and I notice many little things where it is just 'better'. There are some major ways that it is better too like the 10A max charging rate compared to 6A for the Accucell 6 and 7A for the Accucell 8, the 250W max charging energy compared to 50W or 150W, the max discharging current of 7A instead of 1A or 5A.
The settable termination (not really the right term, but you guys know what is meant by it) voltage for LiFe, LiPo & LiIo is a pretty big thing - you can set it at 4.30V for those new 4.35V Li-ion cells. When a new firmware upgrade comes out it may change to 4.35V, but 4.30V would be pretty darned close to a full charge anyway.
The ability to discharge batteries at up to 7A and up to 250W when powered from a 12V battery by using regenerative discharging is pretty impressive. (it will discharge the battery and use that energy to put some charge back into the 12V source battery)
The little difference can be fairly important though like a better UI that saves some time on certain settings changes or offers some 'on the fly' adjustments.
Some that I have noticed so far:
When you go through the options you have Li-ion battery => NiMH Battery => NiCd Battery => Pb Battery => Settings.
From the Li-ion battery menu you have charge, discharge, balance charge, etc
On the iCharger when you go to charge a Li-ion cell you can set the battery type (LiIo, LiPo, LiFe) as well as # of cells & charging current. On the Turnigy chargers if you have been charging LiFe cells then the Li-ion charging menu will be for LiFe and you would need to get out of that menu and into the settings menu to change to LiIo or LiPo battery type.
This really isn't vital and many people only have LiCo chemistry Li-ion cells so they wouldn't really care, but for those that charge their LiFe cells & their LiIo cells fairly regularly then it is nice to be able to quickly change the chemistry type without having to go to the settings menu and then back to the Li-ion menu.
I will still recommend the Accucell-6 for those on a tight budget that are just wanting the necessary features to charge a wide variety of battery types - this charger will handle what most people want to do. But someone wanting more from their hobby charger (like data logging) will be paying more and I would recommend the iCharger range to anyone wanting a step up from the cheaper hobby chargers.
Edit: Info spread out over a few posts to break up the big wall of text
