I might pick up this light
http://www.walmart.com/ip/Black-and-Decker-Flex-360-Clamplight-3-AA/
I've added magnets and flexible stalks to a few cheap lights in an effort to get the same functionality as this (before I saw it).
Checked it out in the store. The magnet needs a cover to keep from scratching stuff, no biggie. Although sealed in plastic, you can flex the clamp - seems strong enough and looks like it has rubber to get some grip.
Strangely, it is $25 in store...while most of the rest of their lights are more expensive on line. I would have already bought it local if it was $15...
Anyway - what I'm wondering is if anybody has ripped one open. I'm sure I won't be satisfied w/ 130 lumens - even if it is an accurate rating - so I'm wondering if it is well suited for modding.
If the optics/clamp/magnet seem good I'll want to get the brightest emitter I can, a variable (or multi-level/mode) driver, and use 14500s. If it is a pita to mod I'll probably just try and swap only the emitter to a more efficient one...
