Maglite D head on C size body
dizhu
Besides lots of grinder and jb weld glue, any other adaptor thing? I prefer holding C sized tube.
Slickseth
Why do you needto use the "D" head? Other than the opening for the body tube, the heads are basically the same.
dizhu
Ahh, I see your point. I am stuck in some thinking process since I only have several Maglite C flashlights and am pondering TerraLux D size drop in.
Techjunkie
in the brightly lit suburbs of NYC (Long Island)
The diameter of the top of both heads are the same, but the C has a deeper shelf whereas the D has a wider neck. Depending on how the TerraLux D size drop-in is shaped, it might fit in the C head with little to no modding. Someone here used to make C neck to D neck adapters for I forget which custom D head (Delghi?, FM?). You might find a used one in BST.
ma_sha1
CT, USA
Good point tech. If only to fit a drop-in, might not need adaptor after all.
As for the adaptor you referred to, I am pretty sure it never existed, there was a thread went as far as take interests on potential offering, but it never got made.
I have searched High & low before decided to grind my own.
donn_
Great South Bay, LINY
I wish someone would make one for sale. I'd love to run 3" and larger heads on C tubes. The closest I have is FM's D/C body, running one of his 3.5" heads.
DFiorentino
MD
That is so weird, I am running the EXACT same parts setup. Mine is using 5 IMR 26500 driving a 64458.
-DF
Mettee
Arizona
I will try making one next week and post back some pictures...should not be too tough.
donn_
The problem will be appearance. A bare metal adapter, visible between the head and tube, won't be very attractive.
I wonder if it's possible to do it in something like black delrin?
ma_sha1
CT, USA
The one I made utilized the bottom of the black D head, no "white neck" exposed.
dizhu
Yes, confirmed Terralux TLE-300M-EX won't fit. The D head must be more squarish inside than svelte C head.
