Found
www.fenixlight.com LD10-R5 and LD20-R5 specs and different websites for LD10-R4 and LD10-R5 specs.
"R4" model historical stated lumens according to old Fenix methodology.
"R5" model stated lumens according to ANSI standard testing.
LD10-R4 Low 9, Med 50, High 105, Turbo 132
LD10-R5 Low 3, Med 13, High 45, Turbo 100
LD20-R4 Low 9, Med 50, High 105, Turbo 205
LD20-R5 Low 5, Med 31, High 81, Turbo 180
Hypotheses - Please confirm, expand, refute.
R5 higher flux than R4 for same given current.
LD10-R4 circuit drives much higher than LD10-R5 - Even turbo v turbo lumen claim doesn't seem merely ANSI adjusted delta.
LD20-R4 circuit drives much higher than LD20-R5 - Looks like runtime was maximized with reduced output.
LD10 / LD20, both R4 and R5 heads are threat compatible but not with older bodies.
LD10-R4 and LD20-R4 heads are interchangeable - battery count changes runtime and Turbo level brightness
LD10-R5 and LD20-R5 heads interchangeability unproven, but most likely interchangeable head with 8 output levels - 3, 5, 13, 30, 45, 81, 100, 180 based upon battery config?
Anyone tested the permutations?
Does the LD10-R5 on two cells behave as an LD20-R5 and does LD20-R5 on single cell behave as an LD10-R5?
Does the "R4" head fit on the "R5" bodies for a matrix of 13 output variations among them.
Somewhat academic as all R4 bodies have sold out.
