Bezel ring removal help!
Chrisdm
Hey guys, I just got a Surefire C2 & a C3, and a couple Oveready bezel rings. I also got the bezel ring removal tool from Oveready, but the factory Surefire bezel rings are so tight that the plastic teeth on the removal tool are starting to strip... Any trick to getting these things off? Thanks!
Mettee
Arizona
place the head glass down, semi boiling water two to five minutes. Should almost fall out. Needle nose pliers will help you spin it out. If it makes sense, use the back of the jaws while opening the pliers. The tips will locate in the plastic at the notches.
