Preon 1 Specifications
- LED: CREE XP-G S2
- Max Output: 60 ANSI Lumens
- Material: Hard-anodized Aircraft-grade Aluminum
- Lens: Optical-grade glass lens with anti-reflective coating on both sides
- Water resistance: IPX-8
- Battery: One AAA, included (see voltage range to select acceptable batteries for this light)
- Operating Voltage Range: 0.9V-3.0V
Read the Preon threads to make sure 10440 can be used ............
4.2 v Li-Ion cell is MUCH over the MAX stated in the specs.
Be sure the warranty won't be voided ...... (check with 4Sevens)
As to being the BEST AAA .......... I wouldn't know ?
