coachclass
- Joined
- Mar 23, 2011
- Messages
- 109
How would you like your flashlights/headlamps to behave when it runs low on battery power?
I don't have a good understanding of what's practically possible with electronics at lower battery voltage/current...so if you have more insights, feel free to write a longer response to explain.
This may also be a multi-part answer:
1) how should it behave on Max when battery can no longer sustain max.
2) how should it behave on low / moonlight when the battery can sustain low, but not max.
I guess my ideal interface would alert me if the battery is almost gone. But, if the battery is good enough for low/moonlight, but not good enough for max, should the light somehow warn me of that? Can modern battery electronics sense that the battery is too depleted for max mode without actually going into max mode? That's important because I may not use max mode very often, and using the low/moonlight modes, you loose count of how many hours you've been burning the same set of batteries. So, before stepping out the door, I'll turn on the light (on low), and if I don't get any indication that the battery is depleted, I might assume I have at least some capacity for max/med modes.
Often, you hear about how lights have such and such runtime, but there's not much focus on what happens at the end of the runtime. I'd like to hear what your flashlights do, as well as what you think they should do.
I've been testing out a Klarus ST20 lately, and found this behavior when the battery runs low and flashlight is on max - the light level goes down, and it goes into a slower strobe mode not found in any of the normal modes. Can't change modes unless I loosen the bezel for moonlight, and it seems that moonlight is the only mode available. Beacon and SOS modes were erratic. After battery gets a rest, I can cycle to all modes (moonlight, sos, beacon, low, med, high), but the medium and high were the same brightness and not very bright.
Opinions?
Opinions?
