Overclocker
Start with the Zebralight SC60
keep the overall dimensions
add some mild knurling for a bit more traction
add a keylock function, a rapid triple click will do. kicks in only after 30 seconds of being OFF.
add cradle charging. just pop it into the cradle when you sleep to top it up.
make it ramp down to a lower modes as battery nears depletion (the SC60 just stupidly shuts down at 2.7V). i.e. switch to medium at 3.2V, then switch to low at 3.1V, or something like that
give it battery level check. double click 8 times to get to this mode. light will blink 1 up to 6 times to indicate remaining juice left.
perfect!
perfect!
