ShineOnYouCrazyDiamond
I've been racking my brain on this one and it now is beginning to hurt. I'm looking for a little input to assist my decision making as I have already ready as many reviews as I can on these and similar lights.
I am currently between picking up one of the following lights:
So my questions are these.
- JetBeam RRT-3
- Fenix TK41 (when available)
- Am I buying old technology with the SST-50?
- Will the XM-Ls be able to out throw the SST-50s while still giving good flood?
- At 3Amps will the XM-L be able to produce as much OTF light as the SST-50 pushed to 5A? What about after running for 10 minutes or more on high?
- Is it realistic to consider a P60 XM-L drop-in with a good 18650 cell which may run for 45-50 minutes on high (obvisouly not in one shot due to heat) as an alternative? I realize throw will be less, but by how much than these bigger lights?
- How are companies coming up with 800 ansi OTF lumen outputs when a T6 bin XML driven at 3Amps is only 910 bulb lumens? There a 10% loss alone just at the junction when temps hit 75*C. I've read the XML takes big dump in efficiency with no real output gain when the drive is above 3A.
