jylong_away
- Joined
- Mar 14, 2008
- Messages
- 39
Hey all!
Have had a bit of a problem with my Surefire LX2, and am also troubled by the response from their WR department...
Was illuminating the contents of a plastic jar about a month ago, and had to get the LX2 close enough that the front end bumped up against the plastic. Noticed a momentary 'flicker' of the light at the moment of 'impact'(it was a *really* gentle bump, which didn't even scratch the plastic or the light). The beam just seemed to go off and then on again for an instant. Have managed to replicate the problem reliably, but only with end-on contact against the front of the light. Tapping it side on or hard shaking does nothing. The beam has also never wavered before during use(unless the battery was about to go).
Tried a new set of batteries, with no luck. Also tried twisting the tailcap to the 'constant on' position to see if it made a difference, but still the same problem.
Has anyone else had any similar problems with their LX2? I have an E2DL and an E1L, which don't do this.
Surefire CS has been another problem - I sent the light in for WR assessment after getting an RMA. They weren't the quickest to proccess it, with their system only registering it as 'recieved' a full week after postal tracking showed it had been delievered.
Just got a reply back from them today after sending a few emails that they couldn't find anything wrong with it, and suggested it might be due to 'sub standard battery use'. That's a bit concerning, as I've used their 123A's in the light, and have a small stockpile back here to prove it. Apparently the light is on its way back to me, with nothing having been done to it.
I find their conclusion a bit weird, given that the 'flicker' only happens when there's impact on the front end of the light. Wouldn't that be more of a loose connection or something?
Any help or comments on the situation would be much appreciated!
Dave
Dave
