I need a project from time to time to keep busy. An sst-90 light seemed to hit the spot. The light was done all on manual machines and has roughly 60hours of machining time. I didn't get the current across the led, but the voltage across it measured right around 3.7v.
Now for some photos:
The front bezzel
The body
The pill. It is a dx sst-90 star mounted to it with artic silver between it and the alum. Inside are 3 dx 20330 drivers with a .5ohm resistor added and wired in parallel.
The body/handle. The grip is sur-grip fabric heat shrink tube. I had to stick the whole thing in an oven att 350F for it to shrink evenly.
The back contact
The Jutco switch holder
The back cap
Assembly
Beam shots:
3d maglight
old 3w k2 light
dx sst-50 light sku:36031
This sst-90 light. Hard to tell from this pic, but the spot is brighter and tighter then the sst-50 and it has a lot more and much more neutral spill
And my last build. 6x ssc p7 light
UPDATE:
So after a bit of use, the light became intermittent and eventually stopped powering on all together. Took it apart to find this:
hmm
x2
Lets take a closer look
Now Im wondering if the chip fried itself and the inductor or the inductor fried the chip. The 3rd driver which was facing the other way is just fine. I think Im gonna try running 4 20330 drivers unmodded (they do an even 2.4amp unmodded each) and not have anything touch this time...
The front bezzel
The body
The back contact
The back cap
Assembly
Beam shots:
3d maglight
old 3w k2 light
UPDATE:
hmm
x2
