BIGLOU
- Joined
- Jan 14, 2009
- Messages
- 717
I do know if someone has posted this or already does this. I have a few flashlight bodies that are bored to accept 18650 batteries. When using CR123s and RCR123s there is a gap between the batteries and the inside of the body. I found using small rubber bands works great lining up the batteries and also provides some type of shock protection. I use the mini rubber bands my wife uses to make pig tails and braid my daughters hair. They are available at beauty stores and at Target or Walmart in the hair products section. I use two rubber bands per battery at each end, but you can put more. They also fit tighter in the battery carrier cases, and stop the rattling. The pack is cheap and must have over one hundred rubber bands. I know people can also use O-rings or wrap the batteries in a Post-It sheet, but this works great. Hopefully this will help CPFers using an 18650'd body with the M91 on two RCR123s or who use CR123s as back up.
