At the threshold of the summer season has decided to optimize the EDC set as a knife chose KERSHAW 1460, as well as a lantern JetBeam Element E3S, but that the EDC flashlight without clips, began to look, but the OEMs have not found that visually the closest was a clip from Nitecore EX11 and how was not mistaken, got a clip as my own, had only slightly modify the hole.
Also fixed lividity of the native light-emitting diode, which was commissioned by cator warm XP-G, but ready to put the star has been difficult, brass insert inside the lantern did not want to get out, well, inappropriately, unsolder the soldering iron with a thin long wire tip from the stars just inside the lantern, up her tweezers and pulled out, whereupon a gas soldering iron warmed only stars below to unsolder and solder diode native warm (did this with the diode itself for the first time, so very nervous, but found nothing complicated) and then adding fresh thermal compound perched on a star place and solder the wires back.
The result is very pleased with the way the diode when molten solder automatic centered on the substrate.
