[ QUOTE ]
Size15s said:
It will take the the P90/P90 if you add an old A19 body extender to hold a third SF123A battery.
It will take the R30 if you use a Z20 battery spacer so that the G2 only has a single SF123A battery.
Of course, once you swap the G2 bezel for a TurboHead, running off two SF123A's it powers the N1 lamp.
Using the old A19 and TurboHead you can power the N2, MN15 or MN16 from three SF123A's.
If you add an AN14 body extender to house the B65 NiCad battery stick can power the old R60 or now the current P60/P61. With a TurboHead on, the B65 NiCad powers the N4 lamp.
[/ QUOTE ]
Wow! These Surefires are more fun than a Mr. Potatohead. All the possibilities. Will the KL3 work on my G2? I'm supposing it will, but since their site didn't specifically list it among the compatible models I thought I'd make sure.
BC
