FS: Mag Charger XM-L U3 Modification - 1000 Lumens
A 1000 lumen XM-L U3 emitter with a 3 mode, 3 Amp driver in a Mag Charger is a nice upgrade for these super heavy duty Mag Charger flashlights...
Great for law enforcement, or anybody who wants to have their Maglite sitting in it's charging cradle, ready for use...
Note: I'm now using the new XML-2 emitters because they are better, but can use any emitter you would like... (I also have XM-L U3 1C on hand)
The Mag Charger is built completely different from the normal Maglite that I show in my other XM-L U3 Maglite thread.
I'm using the same 3 mode / 3 Amp driver for this Mag Charger build, as I am using for my 2 cell build shown in the link above...
The finished mod, is a fixed focus. (best spot) With the brightness of the XM-L U3 emitter, you do not need to focus it. The spill is so bright, that you will always want it in the 'best spot focus'.
The following pictures, show some of the things that needed to be done in order for this mod to work with a Mag Charger...
Switch and heatsink fit:
* Stock circuit replaced
* Stock bulb stem removed
* Heatsink and driver mounting shown
Reflector:
The stock Mag Charger metal reflector opening on the back, gets enlarged to fit the XM-L U3 emitter. The plastic reflector holder gets modified as well. (for fitting my heatsink/emitter)
Battery current draw:
The battery pack, is made up of 5 X 1/2D size NiMH's in series...
I measured battery current draw at the tail: (3500mAh battery pack)
* High - 1820mA's Estimated run time - About 2 hours.
* Medium - 576mA's Estimated run time - About 6 hours.
* Low - 112mA's Estimated run time - Over 30 hours.
Pricing:
The pricing for this modification, is similar to my pricing for my normal Maglite XM-L U3 modification...
The main difference, is the initial cost of a Mag Charger light, with it's charging cradle and accessories. (link below)
If you already have a Mag Charger, you can send it to me for the mod. If not, I will ask for $130 dollars to order the complete light and charging cradle shown here: (which is my cost with shipping and everything)
http://www.zbattery.com/Mag-Charger-Rechargeable-Flashlight-System-1-NiMh?sc=7&category=1290
Mag Charger XM-L U3 modification:
* Mag Charger light with charging cradle and accessories - $130 (or send me your existing light)
* Modify with XM-L U3 emitter/heatsink/3 mode driver as shown in this thread - $126
* Shipping will be calculated on where shipped/how paid - (PM for total)
* Shipping policy:
http://www.sonic.net/~jayrob/MXDL/shipping.html
Send me a private message if interested!
P.S. Here's a great video on YouTube that shows how these Mag Chargers come apart...
Reflector:
Pricing:
* Shipping policy:
