Firstly hello from a LED noob :wave::wave:
I've got myself a couple of lights - a cheap zoomable 3 mode q5 from ebay and an 2 mode ultrafire 501b with a t6 xm-l.
These are to be gun mounted so throw is a major advantage to me. The cheapy q5 is good for this as the zoomable feature can tighten up the beam nicely, but the xm-l t6 has a much better output. Question is - is there any way of tightening the beam on the ultrafire? I know I could put the t6 in the zoomable torch but the build quality on the zoomable one is questionable at best so I intend to use this as a drawer torch.
There is a lot of flood around the hotspot on the ultrafire that is wasted and detracts from my ability to see distance at night, and the angle of the reflector seems to be the problem. Is there a drop in reflector that would help? I tried fitting the lens from the zoomable flashlight but this dropped output a lot and besides is a poor fit.
Any suggestions?
Thanks in advance folks
Any suggestions?
