What is the difference between the Zebralight SC60 and SC600?
JA(me)S
Clearwater
SC60:
  • LED: Cree XP-G Cool White (color temperature 6100-6500 K)
  • Light Output and Runtimes
    • High: H1 300 Lm (2 hrs) or H2 155 Lm (4.1 hrs) / 4Hz Strobe
    • Medium: M1 42 Lm (25 hrs) or M2 12Lm (72 hrs)
    • Low: L1 2.6 Lm (10.5 days) or L2 0.2 Lm (41 days)
    • Light output are Out The Front (OTF) values.
  • Parasitic Drain: 4.5 years
  • Beam Type
    • 80° spill beam spread
    • 11° (3.8 feet at 20 feet) hot spot
  • Dimensions
    • Diameter: 1 inch (25.4 mm)
    • Length: 4 inch (100 mm)
  • Weight
    • 1.8 oz (50 g) excluding battery
SC600:
  • LED: Cree XM-L Cool White (Norminal CCT 6300K)
  • Light Output
    • High: H1 500 Lm with 750 Lm turbo in the first few min or H2 150 Lm / 250 Lm / 4Hz Strobe
    • Medium: M1 75 Lm or M2 21 Lm
    • Low: L1 2.5 Lm or L2 0.2 Lm
    • Runtimes TBD.
    • Light output are out the front (OTF) values. All levels are current regulated.
  • Parasitic Drain: TBD
  • Beam Type
    • 80° spill
    • 10° hot spot
  • Dimensions
    • Bezel Diameter: 30mm
    • Body Diameter: 25.4mm
    • Length: 107mm
  • Weight
    • TBD
SC60w is available now in Neutral White (color temperature 4200K), SC600w (neutral) will be in the future at currently unknown bin/tint.
SC600 has better switch, all levels are current regulated (no PWM), updated styling with knurling, and will have removable/reversible clip.
For discussion on SC60, please see here. For discussion on SC600, please see here.
- Jas.
