As a result of an inquriry on a related matter from K-T, I finally got around to visiting an idea that has been on the back burner for a long time. There is nothing new about the idea but I wanted to see if it would work as a mod on an E series tail cap.
I'm kind of interested in means of tethering and attaching devices and I wanted to replace the rubber boot on the LOTC with a metal post that could serve as an atttachment point.
Since I'm also lazy, I'll steal the text from my web page:
A threaded nut with O-ring face seal is placed inside the stock tail cap. This nut has a smooth internal bore for sealing against an O-ring on the switch post. The switch post is isolated from ground contact by this O-ring as well as an additional isolating O-ring as used on the stock switch assembly. Momentary as well as constant on are accomplished in the same manner as the stock switch. The exposed post can be configured for various applications. It could be threaded for an external lock out nut. It could also have a drilled and tapped mounting port.
I had used something similar on a Ti Arc AAA mod I did last year. I think this kind of tail switch would be very useful on small lights; especially key ring lights.
- Don
- Don
