I just got a brand new Surefire 3" turbohead and decided to try out with a 500 lumen N62 lamp. I'm using Surefire Z3 + A19 that has been bored out to be able to accept the Pila 150A and 168A Li-Ion batteries.
Using 4 brand new SF123 batteries, I was able to measure 19,000+ lux. The brightness begins to drop fairly quickly because I can see the lux readings drop continuously.
I then tried using 2 of the 1800mAh Pila Li-Ion cells with the N62 and surprisingly I also measured 19000+ lux. The brightness using the Li-Ion also drops but not as quickly.
I let the batteries sit for a while and checked the brightness readings again. This time the SF123s gave a reading of around 14500 and the Li-Ion gave a reading around 17000-18000.
I have no idea why the Li-Ions are able to drive this lamp so brightly but so far it seems this is a good combination. I'm going to keep using it like this to see how it performs. Here is a pic of the light I'm using:
