Hi all, I purchased a high intensity Cree LED flashlight a while ago, and when I was tinkering with it, a plastic ring separating the + and - leads from the battery to the LED and the metallic reflector fell out and I turned the light on without knowing it. I'm guessing I shorted something out, because now only my low intensity and strobe modes work, and even they are really dim (it has a high, low, and strobe mode). When I select high intensity, it just dimly flashes for a split second then stops emitting any light. My battery (1850) seems to still be fine since it still can reach its full charge at ~4.2V. Is my LED burned out, or could some other component be causing this problem?
