Last time I checked 2 x 2 = 4mm square, the XM-L is 2 x 2 = 4mm square.
That makes the new XK-? twice the size of the XM-L and 4 times the XP-G.
Also the XM-L can be driven at 3.5 Amps with out harm. Typically electronic
components have a built in 25% head room over the Max ratings on their spec
sheet.
The SST-50 has more output per square mm at the same drive level, but has less
total Lumen output at the same drive level. I was talking about power in vs.
Lumen output, not efficiency per surface area in regards to the Luminus products.
I should have made that more clear, my mistake.
That is also true of the XM-L vs. the XP-G vs. the XR-E. The larger the surface
area allows for more thermal transfer and a higher output as the drive current is
increased over that of the smaller die, even thou the surface brightness decreases.
As the XM-L eclipses the P7 and MC-E, the next Cree will do the same to the SST-50.
Curt
