stephenanderson2
poor man\'s 3x123s to 2d conversion for M*G lite
I went to ace hardware and got two pieces of tubing for the 123s. I cut the small tubing a little shorter than the battery so that the ends would touch when put together. then I took the larger tubing and cut it lengthwise. I inserted the 3 123s in the in the large tubing and cut the large tubing a little longer than the 3 123s in series. Inserted the tubing into a 2d maglite, streched the spring about a half an inch and screwed it all together.
To finish: insert one 6d magnum star and turn head. Do not look into beam!!! /ubbthreads/images/graemlins/cool.gif /ubbthreads/images/graemlins/banghead.gif
I'd put up pics if someone can explain how to post them.... /ubbthreads/images/graemlins/blush.gif
