Erayd
- Joined
- Aug 9, 2009
- Messages
- 25
Hi All,
I'm looking for a new EDC light that fits the following:
My current EDC is a Dereelight C2H - main issues with this are lousy regulation, poor runtime on low modes, the lack of a really low low, and the mode memory.
So - can anyone recommend me a light that fits the above criteria? I've done a bit of searching, but haven't yet found one that fits.
Thanks in advance
Erayd
- Takes single CR123A primary, but would like it to be capable of using an RCR123 also.
- Ideally 4 modes (OTF): <0.5, ~30, ~100, >200. If this isn't available, then replacing both the middle modes with something around 50l would also be OK. Programmable would be ideal, but this isn't a requirement. UI-wise, I find the ArmyTek Predator to be brilliant; if something like this was available in a 123 format I'd buy it today.
- No mode memory, or the ability to disable this. I generally like my lights to come on at the lowest mode each time. Level selection should be ramp-up.
- Flat regulation - the light should keep the same level until it runs out of juice. Would be nice if it could drop to the lowest level when the battery is almost dead.
- Forward clicky (tail switch preferred, side OK). Not too fussed about the mode-change method; most implementations should be fine.
- Must tailstand when switched on, don't care about tailstanding when off.
- OP reflector, some throw is nice but I prefer medium-distance flood for an EDC.
- Decent tint; cool white is OK, but it needs to be *white* - things like purple tinting are unacceptable.
- No clip, or removable clip. Can live with an unobtrusive clip if necessary to get some of the other features I'm looking for, but I *really* don't like clips on my lights.
- Good build quality - I'd rather pay a bit more for something that's going to last
Thanks in advance
Erayd
