I was digging around, and didn't see anything specifying differences on how some of the driver boards are mounted into/onto the drop-in pill. I was curious if there was a simpler way to do it, other than soldering. I do not want to fully pot it though. I would like to have the ability to modify it later.
I have enough skill with a soldering iron to get by, but I was having some difficulty with solder on the "brass" pill adhering. I had it cleaned really well, but it seemed to just not get hot enough. I could probably benefit from using a little higher temp - as long as it's not so much I'm frying components, melting stuff....etc.
Also, if someone can post a technique - order of operations so-to-speak - for assembling the driver to the pill...that would be GREAT!
If there's already a tutorial or explanation out there, then I missed it. I did a search first, but came up with mainly other builds and customs that didn't explain that part. They simply stated, "installed driver and then....."
THANKS!!!!
THANKS!!!!
