Ok guys two things first lets start with the fun pics. These pictures are of a regular maglite without the very top plastic piece and a 5mm LED from a donor Lighthound free keychain led seen HERE I used a reflector from the nite ize LED II kit as well here are the results when the head is fully tightened down and it lines up perfectly for the best hotspot on a lucky draw.
Also this was all thanks to what I have learned here on the CPF lovecpf
This first picture is of the light on with the head fully tightened down and the thing in front of it is the piece I removed to make this happen
This is a picture of the hotspot in a room with one light on
And last but certainly not least is a picture of the hotspot in a completely dark apartment:wow:
Now onto other ideas... Could this work using just an emitter that has two wires coming out of it and use those wires as bi pins similar to the extremely crude drawing I made here.........
Would this idea work with a dummy AA and 1x14500 with a low 0.9-4.2v emitter maybe like XR-E?
