So how do you use the interface on the SC51 Zebra light. I took some time to try and make it easy for those wondering.
Easiest place to start is when the light is off.
From off: Quickly press and release the button and you have high mode.
From off: Quickly double press the button to get to medium.
From off: Press and hold the button for half a second and you have low mode.
From off: Press and hold the button down and watch the light ramp through all three main modes which are (from that point) low, med and high and round again. You can take your finger off the button when you reach the desired level (low, med or high).
Whatever mode you are in (low, med, high) you have a secondary mode. So if you are in low quickly double press the button to get to the secondary low mode. If you are in medium quickly double press the button to get to the secondary medium and if you are in high quickly double press the button to get to the secondary high. Whatever mode you are in when you turn the light off will be the mode that you get when you turn the light on. So if you are in secondary med mode then when you scroll though to med or double press into med mode the light will come on in the secondary med mode.
The high has two levels of secondary mode which is either a secondary constant on or in place of that a strobe (and there is only one strobe). When you get the light it will offer high and secondary high (constant on) so you have to reset the light to get that strobe going.
This can be confusing so the best way I do it is as follows.
To set the strobe turn the light on to high mode and leave it on a second or two. Then quickly double press the button 9 times. So //,//,//,//,//,//,//,//,// then leave it a second and then turn the light off. Now when you go to high mode and double press to get secondary high it will come on in strobe.
To turn the strobe feature off: Turn the light on into high and leave it a second or two. Then double press the button 8 times, so //,//,//,//,//,//,//,// then leave it a second and then turn the light off. The light will now go back to it's shipped status which is high and secondary high (constant on not strobe).
