I'm relatively new to LED flashlights, and am looking at purchasing one of these 3 models:
Quark AA Tactical S2
Jet Beam BA10
Fenix LD10
Can anyone make some recommendations on which way to go?
Thanks.
If you hang around here very long you will wind up with all three.
I take it you want a single AA light. decide if you want it geared more to flood or throw (most single AA are floody though) and if you want a forward clicky (Quark tactical) or reverse clicky (Fenix). Look at the UI of each light and the run times. Once you figure all that out you have to decide which of those feature are right for you. The LD10 and Quark AA are nice lights. I know nothing about the BA10 - it is brand new and it is Jetbeams "budget line" so corners may be cut. Also, check out the Zebralight SC51. You may want to look into neutral tint options too. Many here no longer like the bluish tinted light of cool tinted emitter and instead opt for neutral.
Reverse clicky is just click-on, click-off.
Forward clicky is press in for momentary on, click-in for full on.
Jet Beam BA10
Fenix LD10
Thanks.
JetBeam BA10.....forward clicky, tail-stand and the most affordable among the three.
Down side......only 2 mode.
What's the relevant amount of use? All the Quarks I know of (and have) are just PCBs, and those layers don't look pristine even on new lights, but they have a 10 yr warranty, and I haven't seen complaints of this sort of failure.If frequent use, then you may look at wear issues. Check pictures of the head contacts - are they thick metal pills/rings or just PCB thin layers? This is especially important with "twisty" lights, where the tube/battery will rub against those contacts when operating the light, and overtightening the head may strip the PCB ring that comes in contact with the tube.
