molon_labe
- Joined
- Jun 7, 2010
- Messages
- 59
I was looking at these two lights and wondered which one is a better light. Any news about an RRT-2 XM-L Inf V?
Thanks for that info on the Jet III-M XM-L Rat, just one thing mate does the Australian dealer that you buy your JetBeams from have a Website where you can buy from them online?
mvyrmnd was spot on with his post.
I got my Jet III-M XM-L today.
It's a great light the beam is similar to my PC25. The PC25 has a little warmer tint than the Jet. As with both XM-L lights they are more on the floody side than throw. But the Jet throws better than the PC25 it lights up my back fence a little better than the PC25 with the brighter hot spot. It's still not a thrower like my Jet III-M R2 with the smooth reflector.
Now which one do I prefer ?
The Jet III-M by a mile is my chose it just has to many cool setting that you can change to meet any of your needs.
I prefer the beam pattern of the Jet on high over the PC25 and the extra 50 lm is noticeable. The option to change the settings in the second mode is just great. You can set from a very very low setting all the way up to high. It ramps up slowly and you just push the button in when it's at a brightness you like. There is also a lot of special functions you can choose. You have a strobe that you can set from 1HZ to 15HZ. You also have a warning signal, stanby signal, 100% SOS signal or a 5% SOS signal.
The Jet III-M build quality is better than the PC25 typical JETBeam high quality as in the RRT range.
I am a big fan of the side switch on the PC25 with the access to the 4 levels it's great but get the Jet III-M XM-L you will love it.
Hope this helps you a little.
cheers
I'm looking into purchasing the Jet III M plus a bunch of accessories as well. Being completely new to this, I noticed that one of the accessories is the bezel remover:
http://ep.yimg.com/ca/I/blackforce_2160_25461907
Is that something I need to replace the base bezel with the crenulated bezel? Does anyone know how well the light with the crenulated bezel will fit into the holster?
Hotlinked image replaced with link.
Norm
