LED_ASAP
It seems odd--there has been quite a few AAA-sized commercial lights and mods that use under-driven Luxeon emitters, but there has been only one AA-sized Luxeon mod that nukiez made from a Infinity Ultra /ubbthreads/images/graemlins/confused.gif
According to nukiez, the original Infinity Ultra board has problem pumping out more than 160mA from a 1.2V source---kind of the same observation I made in my Solitaire and Arc AAA LS mod---the ZLT circuit becomes unstable if you try to get more than 600mA battery draw. But with the energy density of 2100mAh NiH, it would be interesting to try pushing the current up a little. So, I decided to take up the challange of building a more powerful single AA LS mod.
I planned to use an Infinity body and a cut-down version of NX-05 as the optic. When I started digging, I was quite disappointed at the construction of Infinity---the roll-crimp on Infinity is really thick and almost impossible to crack open without breaking some pieces /ubbthreads/images/graemlins/crazy.gif After hours of drilling, boring, and filing, finally I got the bezel to the right size and shape that will properly accomodate the LS and the optic.
The NX-05 was sawed short and polished
Here is the bezel with the lens in the cavity
I couldn't think of a good and simple way to hold the lens in the bezel. They were simply epoxied together---too ugly to be shown here /ubbthreads/images/graemlins/frown.gif
The Luxeon emitter was mounted on a brass disk like I did in my Solitaire mod.
The electronic part is based on the ZLT unit, but with some modifications to allow higher current. It pulls 900mA from a single NiH battery. I don't know the output current, but I would expect something in the 300mA range.
Size comparison among Arc AAA, Infinity LS mod, and Micro Illuminator:
The output is very satisfying. It has a squareish hotspot plus a nice side spill, similar to the typical beam of a HD with a NX-05.
The hot spot is brighter and a lot bigger than that from a MicroIlluminator:
2 level under-exposure
1 level under-exposure
And it totally blows the stock Arc AAA away
Overall I am happy with the results, but a lot work will have to be done to make the bezel look prettier.
