Interestingly, you chose kind of a challenging host to pick a drop in for. The fact is that most drop in modules require at least 4.2 volts for regulated output. With two AAs, you're only looking at about 3 volts. Unless of course you want to put 2 X 14500 Li Ion in series, in which case you'll need a very high voltage drop in. Luckily for you, Solarforce has you covered on both fronts. They have a good selection of drop ins centered around the Cree XPG emitters that will operate at very low (.8 - 4.2) or very high (4.2 - 18) voltages.
Please see the sales site here:
http://www.solarforce-sales.com/product.php?t=RB and click the drop down to look at the options offered in these "extreme" voltage ranges.
I have to think that a low voltage, 3 mode drop in running on a couple of Eneloops is your ideal setup here. I would probably go that route rather than trying to squeeze a couple of Lithium Ions in there. You'll have higher capacity, better efficiency, and your whole setup will be safer.
I bought it, honestly, because it was inexpensive... only $11. Also because I prefer the AA format. While I do have some 18650 lights, for lights that I'm going to be relying on for longer periods of time, like camping, hiking, and backpacking, I prefer to go with AA.
I'm not opposed to running 2x14500; but thanks for pointing out the voltage issue. I did have a rough idea that I would need to take that into account, just wasn't quite sure how it cashed out with this format.
Another reason I decided to get it is because I want to get the lantern head attachment, and the color filters too... I'd like to be able to use it for things like star parties, camping, etc.
My favorite drop-in for my L2r is a dereelight 3SD XPE neutral Javelin drop-in. You want the 0.9 to 4.2V version of the drop-in (they are available in two different voltage ranges). You can currently chose from an XPG, XPE R3, or XPE R2 with a neutral 4A tint. The XPG has great throw with a nice big hotspot and decent spill. The XPE has a smaller hot spot, less lumens, less spill, but even more throw than the XPG. The 3SD version has 3 modes (high, medium, low) without any strobe or other disco modes. It has last mode memory and will fit perfectly into the L2r. I have both the XPG version and XPE with 5C tint. It will run you $35 direct from Dereelight and you may be able to get it at flashlight connection too.
Again, make sure to specify that you want the 0.9V - 4.2V version.
That sounds like a good option; I'll check it out. I think for most uses I'd want to go with the XPG as I'd be using the light most often for camping and the like.
Solarforce nuetral tint 0.9-4.2 works great. I think SolarforceUSA sells them too. Get an Orangepeel reflector, if you decide to run two 14500's get a 3v-18v dropin
Do you know the specific model number for this one (low voltage neutral)? I looked at their site and they don't specify the tints clearly; they mention some binning, but I'm not familiar with some of the less common tint bins outside of the 4, 5, and 7 bins.
Thanks guys, I'm looking forward to this... (A little while ago, my wife said "You bought ANOTHER flashlight!!!? LOL...
and I said yeah, and I used my own money for it too! So nyah!!!)
