It looks like it would work, though it would be on par with an XP-G based 7up board. the Rebels run at 320 lumens, 2.85V, 1A, so 112lm/w. The Cree PCT says an XP-G R5 does 320 lumens at .9A, 3.35V, or 106Lm/W
Slight advantage to the rebel's not a ton, I'd call it 6 in one hand half a dozen in the other. (unless you want color! then definitely rebel all the way!)
Even with a 3x XM-L outputting 2100 lumens, (700 per LED) its at a 2A drive current, 106lm/w, still a wash, though slightly cheaper price for the LEDs.
a quad XM-L doing 2100 lumens (525 /LED ) is ~1.4A and 119lm/W. Slight advantage to the XM-L, again, not a ton, and youre spending the same on LEDs, with the only advantage being possibly bigger optics can do a tighter beam and throw further. (however I dont know of any quad XM-L optics, so again, wash)
7 of the rebels would be 19.95V divided by 16 cells is 1.25 V/cell so you could run it in a 16AA -> 4D adaptor with direct drive (maybe a resistor if they are too hot off the charger) You could also use a max-flex from taskled in a 3D mag package with 26650s
Certainly seems like a nice combination! When are you putting one together? :nana:
