Please help me identify this Surefire light
Boaz
Well this is my first post, I have been reading and searching around for answers.... If this is not the correct place to post this please let me know and I will post it in the appropriate area.
I purchased this used from a reputable seller on a local gun board. I like the light but am a bit puzzled with its origin. Is it possible this is issued gear from the military?
It has the M93 latch
P60 bulb
what appears to be a Flat Dark Earth factory finish
Black push button/tail switch
IR filter (not pictured)
The number under the surefire logo is a374067. It is a quality light and I do not suspect it to be chicom crap. Help me ID this light!
I called surefire today and was told the M951 was never offered in TAN with this config... I did not have the serial number with me today when I called..
TMedina
That looks like a M952 - but Size15 is the subject matter expert.
As for US military issue - maybe. It's not mass issue, for certain but it's easy enough to believe individual units purchased and issued the gear out.
-Trevor
angelofwar
South Carolina
That's an M951. The M952 had the thumb screws, where as the M951 has the throw lever, IIRC? Looks like an army guy put a custom paint job on it, or it may have been custom assembled for some Special Forces units, as far as the finish/paint job.
ebow86
Pennsylvania
Looks like a homemade paint job but how do you explain the surefire logo? Is it recessed or something?
nbp
Wisconsin
Al!!!! Where are you?!? :candle:
He knows everything about everything when it comes to SF weaponlights.
brightspot
looks to me like you have M952XM07 / FM63KIT and it is available in desert tan.
angelofwar
South Carolina
Ack...M951 is the thumb screw...Too many numbers...must defrag hard-drive...
Size15's
Kettering, England
As mentioned, its a Desert Sand (-TN) version of the M952-KIT01 (M952XM07 + FM63).
If you order enough of certain model you can have it in pretty much whatever colour you want.
More commonly issued now is the M952V-TN because it doesn't need an IR BeamFilter. Given the demand for WeaponLights in Desert Sand SureFire now offers a number of models as standard options in -TN as well as HA or Black HA.
