So am looking for a decent EDC and I liked both of those lights and they are both at the same price but I wanted some advice from those owning those flashlights
I went toward the M10R for the CR123 since it would be smaller, the M10R length is 8.2 cm while the V10R is at 150mm which is a little under double of the M10R, as for the peak I already sent them a request but I am not expecting to get a response from them any time soon and I tried to order from RMSK but he doesn't ship international. I don't wanna end up with a quark or fenix E05 as I already have the TK35 and want something premium for my EDC
Wow, the secs. listed for the V10R on Sunwayman's website are incorrect. Like Skyfire said, the V10R and M10R are the same size and both take a single CR123. Look up the V10R on Batterjunction.com. for correct specs.
Sometime this week I will be receiving a Logan SS QTC and will give my impressions. From everything I can gather it should be pretty much bombproof, mine is coming with the OVEREADY clip ( http://www.oveready.com/peak-led-fl...steel-pocket-clip-silver/black-/prod_193.html ). Actually the QTC should take care of any battery crusher tendencies of a twisty. It will come on low first but with a fast twist it will come on high. Since there is no real switch or mechanical brightness control there should not be problems in these areas. No electronics or magnetic control to go wrong and the simplest UI in history, all intuitive. I will be comparing it to my PD McGizmos and Sunwayman V10R Ti. The optic has the advantage of being super tough and if it does get scratched it can be easily polished out and should also add to its ability to be waterproof.
