gcbryan
I'm not familiar with all of the models of all of the manufacturers so some feedback would be appreciated.
Is there a relatively light weight (1) 18650 XP-G or XL-M with a diffused output? I'm thinking of something like a P60 with a smaller head. I'm not looking for throw so I don't need a large head. I'm just interested in 1-300 lumens so a fully driven XP-G or an under driven XM-L are fine.
What I would really prefer in additional to the above would be a ring control for on/off and as an infinite adjustment for brightness. That seems like the most natural user interface. I guess a side button that did the same thing would be something to consider as well.
What comes closest with the usual manufacturers (not higher priced custom dealers).
I guess the question is are there any ring or side button user interfaces that are close to what I'm looking for and if not at least perhaps someone can direct me toward a single 18650 light that doesn't have a big head.
I have a P60 style single 18650 body with a 3 mode XP-G that I've added a diffusion filter over the lens. As far as light output and beam quality this is fine.
I'd like for it to be lighter weight. The battery isn't where the weight is. It's the machined aluminum but much of that weight is in the head. With a diffusion filter however there is no point in a larger head for throw so the head could be much closer to the battery tube diameter.
I'm kind of tired of tail clickies as that means I have to use the light in an unnatural way (IMO) and there is no need to click through all the options to get to a certain light level. If the button were on the side even if I had to use multiple clicks it would feel more natural. If it had a ring it would be more direct and even better.
That extra weight just seems unnecessary. Even a reasonably small light like a P60 host is still heavy compared to yesterdays inferior lights that were in many cases made of plastic. Or even some of the aluminum ones didn't seem as heavy although I sure they were since they were larger but the weight was distributed a little differently.
Any suggestions?
Any suggestions?
